How to check how many times the battery has been charged
How to access program to check number of times battery has been recharged
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hey Ray,
The answer to your question will vary depending on the status of your iPhone.
If you iPhone is jailbroken, then go to Cydia and search for BatteryDoctorPro from BigBoss.
This little utility will help you manage your battery to make it last longer and also show you
the cycle counts ( number of charges ).
If your iPhone isn't, you'll go on google and download the following program: IBackupBot.
This utility will let you access backup from itunes, data from you iPhone and some diagnostics informations such as the cycle counts of your battery simply by plugging your phone in the USB port and starting the application. A windows will show up, then you'll have to click on 'more informations' in order to see the battery information.
If you have any questions, feel free to post it here!
Best regards,
Bruno
There you go :)
Bu yanıt yardımcı oldu mu?
As suggested I downloaded lBackBot and was able to access a great deal of data,but could not find "more information" so that I could have check battery cycles.Thankyou for your help.Ray
Hi,
after you've plugged in your iphone to your comp via usb and opened the IBB program, then in the (bottom part) of the window on the left of the program, you will see your phone listed. once you click on that, you can see a "More Information" link in the main window of the program. Easy from there. good luck!
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 15,465
