Ana içeriğe geç
-EF Mount Lens -Aperture Range: f/3.5-36 -Optical Image Stabilization -Ultrasonic Autofocus Motor -Internal Focusing System -Manual Focus Override -Constant Minimum Focus Distance: 20" -72mm Filter Thread Diameter
Canon 28-135 f/4.0 IS USM Lens resist on turning
Hey guys
i totally no idea why does my lens resist on twisting whenever i zoom in or zoom out, i does require a certain amount of force just to twist the barrel of the lens.
how to fix this?
Bu iyi bir soru mu?
Puan 4
1 Yorum
I have the same problem and it has gotten worse to the point that the lens is almost unusable
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello Jan!
if the barrel is broken, you will need to replace it and additionally buy the CANON EF 28-135MM F 3.5-5.6 IS BASE ZOOMING GUIDE by $6 USD
http://www.procamerarepair.com/search.as...
i EXPECT can be usefully my answer.
good luck!
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
The same thing happened to my lens and I tried to zoom in and zoom out forcefully and suddenly it snapped and a ring broke in my lens so don't try to apply force. I watched this video on YouTube to fix my lens but I seriously advise you to get it fixed if you don't want to try to fix it by yourself still I am copying the link to the video. Hope this helps.
https://youtu.be/PMUXqfTEXsA
Puan 2
Yorum Ekle
my lens is stuck at 135, i mean it believes that is at 135 even though i am at 28, anyone knows something about that?
Puan 2
Yorum Ekle
It could be that the lens threads are out of position with a slightly bent lens.
This has helped me getting it fixed, maybe that also helps others
https://www.youtube.com/watch?v=_4K1Ge5C...
Puan 2
Yorum Ekle
Yanıtını ekle
Jan Buencamino sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 4,521
