How do I change my starter?
how can i change my starter for a 07' sportster
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It won't be fun.
1. remove battery
2. remove primary cover (leftfoot peg probably needs to come off to do this)
3. remove rear exhaust pipe
4. remove (you might get away with just loosening this) the drivebelt front sprocket cover (right footpeg and front muffler might interfere)
5. remove starter wiring
6. remove starter bolts
7. remove starter
reverse procedure to install
In addition to the starter itself, you'll want to have gaskets for the following:
- rear exhaust port
- exhaust crossover tube
- primary cover set
and oil to refill the primary chain case
Bu yanıt yardımcı oldu mu?
How do you change starter in 86 harley sportster 883
I think that is first year evo, so it should be similar to above.
Ok thanks it's alot of work to remove the starter
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 8,441
1 Yorum
How to change a starter on a 1999 sportster
bain_c tarafından
