Can I install a 2TB SSHD on my iMac?
I just tore down my iMac and found that it had a 500GB WD Blue HDD. I want to upgrade the HDD but I would prefer if the upgrade was tom something like a 3.5" SSHD, such as this one: http://www.amazon.com/Seagate-Desktop-3-...
Is it possible to install said SSHD when the iMac came installed with a WD Blue? If not, is it possible to install a 2TB Seagate Barracuda or will it have to be a WD drive?
Bu iyi bir soru mu?
2 Yorum
Did this hard drive have a plug in for the heat sensor?
mayer tarafından
Yes, the hard drive did have a temperature sensor. I assume you're referring to the 8-pin connector right next to the SATA power and data connectors?
Muhammad Alwan tarafından
