Ana içeriğe geç
Eighth generation of the Honda Civic.
53 Soru Tümünü görüntüle
How do I change my fuel filter
What steps and how do I change the fuel filter in my 2010 Honda Civic?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
1 Yorum
Location of fuel filter on Honda covic
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Albert Miller, it is bundled with the fuel pump, pressure regulator, and fuel level sending unit in the gas tank. There is an access panel in the trunk in the middle of the floor right behind the rear seats
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
This might help you. https://youtu.be/wzRdwpUJ1OM
Puan 2
Yorum Ekle
Your car does not have an (external) fuel filter like older Civics. It does have an in-tank filter that is connected to the fuel pump, which is in the fuel tank.
Puan 1
Yorum Ekle
On most modern vehicles, the fuel filter, fuel pump, sensors, and other ancillary hardware are all located in the gas tank. They're designed to last the life of the vehicle and as such aren't easy to service. Gasoline is pretty clean these days so there's little reason to change the filter unless you have a specific reason.
Puan 1
Yorum Ekle
Pick problems in hilly areas. Sometimes raise in temperature by two bars
Puan 0
1 Yorum:
My 2006 Honda Civic hybrid keeps jumping as I'm driving what would cause this
tarafından
Yorum Ekle
Yanıtını ekle
Albert Miller sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 152
Son 30 gün: 582
Her zaman: 41,708
