Ana içeriğe geç
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Soru Tümünü görüntüle
Soru Kapandı
Best tricks to remove iPhone 5C battery glue?
Hello everyone,
I just tried to change my iPhone 5C battery yesterday and i damaged a chips on the board so my iphone not working anymore.
What is the best way to remove the glue under the iphone 5c battery, i tried with plastic card and that not the best.
What is the trick without touching mother board ?
Thanks alot
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
It would be difficult to remove it without touching the logic board, or at least removing some of the screws. The least you can do is to remove the charging port, so that you will have full access to the end of the glue (near the charging port. there is a piece there attached to the glue strip). Pull the black piece out, cut it in half, and pull the glue strip gently one side at a time (there are 2 glue strips at the bottom of the battery). hth.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Honestly, this battery can be difficult to remove if it something that will be reused after putting it back together, if not just be aware of where the logic board is, you want to be as careful as you can but Im sure you already knew that, make sure that the battery is disconnected from the logic board first, and since you are replacing the battery there is no need in being nice to it, if you have followed the steps in the guides on this site and they didn't help then i would suggest getting some kind of flat tool like a spudger or a flat head screw driver and very carefully pry it out while avoiding the logic board, just work your way around until it comes free, *This is just my opinion on what I would do with MY phone, some might not condone it here but again this is just MY opinion*, hope i helped
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 180
