Spot on new screen
I purchased a battery and screen assembly from i fixit. After reassembly there is a yellow spot/patch on the top left part of the screen. Any idea? Defective screen or reassembly error?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Have you pushed the screen a little too hard and too much ?
Anyways email support and attach photos and you should get a replacement. There is not much else you can do
Bu yanıt yardımcı oldu mu?
No. Only light/delicate pressure and only on edges.
Haven't located email address for support yet. I am sure I am just overlooking it, but haven't located.
It`s called B grade LCD assembly, that`s because the quality of the screens is not good enough...That happens sometimes, unless you buy pure original screens from Apple, please notice.. it`s Apple... not Foxconn...
Try this-open the screen removed side screws of the frame and re screw them but screw them with no force I tell they are in...once there in the frame do not tighten them up light you normally would leave them loose and see if this help.yellow spots are caused by tension-like from the frame or sometimes over heated lcd during refurbishing.
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 111
