Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
iPhone 5 charge issues
Replaced battery in iPhone 5, worked fine for about a month, then dropped phone, got a small dent in bottom left corner and one in top right. Screen cracked. Started having charger issues, when battery drained it wouldn't charge, only displayed a red battery symbol.
Rebooted it with home+lock button pressed for 30s and after that it jumped to life after having charger plugged in for 2 minutes.
Replaced cracked display and cleaned out the lightning port from lint. Did a full reset in iTunes. Still having charger issues. Sometimes when left charging over night, battery percentage hasn't gone up. This problem has occured after dropping phone. What could be the issue? Lightning port?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
robertdanielsson, start off with replacing the battery and the lightning connector. If the phone still will not charge after that, you are having issues with the charging circuit (power management IC) on the logic board. That will be a very difficult repair, if even possible.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
So it's one of these three?
I've also tried charging in different computers, different lightning cables, iPad and iPhone charger (genuine), won't help.
tarafından
Yorum Ekle
Yanıtını ekle
robert sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 154
