Ana içeriğe geç
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
Will not load windows
Windows 7 will not load
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
5 Yorum:
Have you tried safe mode? what have you tried?
tarafından
Be more specific, please. Give as many details as you can so anybody can help you.
For example, tell us, Does the laptop turns on? Can you see the Dell logo screen?
tarafından
Mine loads to CRPdsk.sys and then crashes out and will not boot with original disk it came with containing Vista PREMIUM or any recovery processes.
tarafından
I ran diagnostics and everything in the system passed; tried backing up to earlier time to no avail. I have re-seated the RAM. I tried to run it on only the 1st stick of RAM. Tried recovery, chkdsk, scan etc. nothing. It just blue screens out at that same place - sorry think it crcdsk.sys not crp!
tarafından
Also tried safe mode and everything under that menu.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Dell Inspiron 1545 boot loop....
I ran diagnostics and everything in the system passed; tried to reload hdd with new os... system came back with the error code that no drive was loaded. (Basically could not read the hdd). Replaced the HDD with a new 250 GB HDD and tried to load OS, same issue. I have re-seated the RAM also. I tried to run it on only the 1st stick of RAM. Next attempt I will try to load the OS with 1 stick of RAM, but I do not think it will work. I am open to any other suggestions that anyone has. I am fixing this pc for a co worker and was not wanting to take it all the way apart, but I will if necessary? Suggestions Please...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
strugalamartin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 490
