Valve cover gasket replacement
I am going to replace leaking valve cover gasket on my 2003 Suzuki Aerio. Do I need a toque wrench and specs.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Yes you need an even torque to get a good seal the torque is 89inlb or 7.5ftlb. work from the centre out and rotate from end to end. make sure all old gasket has been removed and that both surfaces are clean and dry. Don't mickey mouse it or it will leak again.
Bu yanıt yardımcı oldu mu?
No, but be careful not to overtighten - if you bend the tin it will leak forever.
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,346
