My Google process gapps. has stopped stopped
Google process. Gapps has stopped,
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If the problem persist even after a power cycle, you have a software issue with GAPPS running on your device.
The simplest fix is for you to enter "recovery" mode on your device, then perform a Wipe. *NOTE* THIS WILL FORMAT YOUR DEVICE
1. Enter Recovery Mode
https://www.youtube.com/watch?v=togllOW3...
2. Perform - wipe data/factory reset and wipe cache partition
3. Restart and reinstall your apps.
The long fix
1. Enter Safe Mode
https://motorola-global-portal.custhelp....
2. Go to settings / Applications Manager
3. Locate the GAPP that are crashing and see if you could reinstall / disable or roll back to an older version.
4. Reboot your device and update the GAPPS via Google Play and see if that helps.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 143
