Ana içeriğe geç
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
20 Soru Tümünü görüntüle
Some portion of motherboard is overheating
When the battery was inserted then the portion 2 inches below the f1 fuse was overheated but when i plug in the power then there was short circuit two inches away from the right side of touchpad and smoke came out...
What happened to it ? And what should i do now?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
At our labs we hook up an external adjustable PSU and slowly increase the amps whilst monitoring with thermal imaging camera for overheating components. Once found we replace them and repeat the process until the board is repaired. Some of the components can also be tested in-circuit, so would suggest testing all diodes and resistors around the area that gets heated up.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
solder whatever component that was heating up off the logic board afterwards, plug the charger it again to see if it still heats up.If it doesn't that mean the component you removed was damaged and needed to be replaced.
Puan 1
Yorum Ekle
Yanıtını ekle
nomanghous sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 250
