Ana içeriğe geç
Sony Xperia J, Android yazılımıyla çalışan bir akıllı telefondur.
Problem with network signal
I have a problem with my network signal.
I opened phone and found out that the connector from the second (lower) board has broke.
By the connector i mean the one that has a screw hole in it, its by the vibration mechanism.
picture of the board
So i would like to know if that's why i don't get network signal, or should i investigate more?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
Do you mean this connector?
Resim
If this connector is broken you may have a problem with network signal strength. You need to solder it or replace this subboard. A good idea is the replecement of the rf cable (a black cable connected to this subboard).
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
The problem that you state.have different problem with mine situation
Puan 0
Yorum Ekle
It seems that the RF connector is damaged...kindly look at the condition maybe that is the reason and you need to replace.
Puan 0
Yorum Ekle
Yanıtını ekle
filerzr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 23
Her zaman: 3,189
