Small dent on mesh metal of beats pill 2.0
how can i remove the mesh metal of the speaker to get to the back of it so i can smoothen out the dent
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I have a 2.0 and yes it will slide off, just give it a slight hard pull and it should slide right off.
Bu yanıt yardımcı oldu mu?
How do you put it together will it just clip in? Or does glue need to be used
Follow this guide to see how it’s opened:
they slide off the side pretty easy. Just pull really hard and it should come off
it slides off at the sides just needed to clear that up
do i just pull it off its a pill 2.0 not a 1.0 if theres any difference
How? i cant do it...
i have the 2.0 and it will not slide off please help
It won't work for me either not sure what to do now
Dissasemble per all of the vids out there and then gently lift the corners of each speaker grill that are closest to the beats "b" in the center, you may have to go back and forth between top and bottom corners but then they should just lift off or slide out
You could use a knife and slide it on the top and pop it off or slide it and to fix the dent you could use a flat screwdriver and push the dent some people use also other equipments. So feel free to try them all!
The mesh is somewhat hard. You will have to obviously disassemble the mesh out of the speaker body and then use a rounded tool ( like the handle of a screwdriver ) to push the bump out ( put the screwdriver in a table, place the mesh on top and the n push gently). That worked like a charm !
How do I fix the beats pill plus grill and the grill keeps coming out and I need help to force it in back any tools
Take off the mash grill and find a plastic hammer and light hit it times where the dents are in the mash grill you wanna tap it and wear gloves and wear eye protection goggles
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 14,729
