replace internal hard drive with SSD
Can I put a SSD into my Mac mini mid 2011. If so is there a preferred brand or special SSD to buy?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi Stewart!
There is no problem putting an SSD in that machine. I usually prefer the Samsung 850 EVO.
Kind regards
Hi Stew!
Overnight it came to my mind: Depending on your OS you should install TrimEnabler or Chameleon
If you are running the latest version of Yosemite, use the command line and type: sudo trim force enable You don't need any 3rd party software anymore.
That should help extended SSD's lifecycle.
Kind regards from Krautland
Bu yanıt yardımcı oldu mu?
Its so sad, isn't it ?! Ever since ⁄ƒ⁄≈⁄† belongs to åππ@€ , censorship is not just a word, its taking place. Thats what I just found out on this last of my comments: I'm reading things, that I never wrote! I wrote Yose‚ª⁄†€! What do U read ?! Yosemite!!!!!! What I was trying to write, without being banned for bad behavior, was ' YOSESHITE '! & Now???!!! : Where is ya' ' Freedom of Speech'? Wozniak be praised:
cmd + shift + 3 ( 4 ) still works ! I've got several proofs!!!!!
Efff off & sick my Duck!!!!! I really wonder............
@Alexander - Keep it clean and please use proper roman characters so people can understand what you are saying.
I installed an SSD from scandisk from conrad Germany.
But what I tryde nothing brings this equipment alive.
Also the company Conrad comes with the righte answer.
Did you install the OS onto the drive before you put it in?
Guide daag , Joost! Well, what did do , to animate this SSD! Usually, they come unformatted or at least ' Master Boot Record ' . Did u go to 'Disk Utility' & gave it the ' GUID & Mac OS x Extented ( journaled ) format ? If Disk Utility does not see it at all ( internally & externally via USB / Fire Wire ) , give it back, its chuffed!!!
Kind regards from Moffenland
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 2,250
