8-in-1 media-card reader not reading card
card reader not reading card. is there a test for driver software and where do I look for it , or install new card reader
Bu iyi bir soru mu?
Puan
0
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 218
Is this a new card reader? If so maybe download the latest driver from the manufacturer. Usually found in support or downloads section of the company website. Also is this a new card? If so double check that it's type is compatible with the reader. Often newer versions of common card types are not supported by existing readers.
Brian JJ tarafından
Another thought is that the card reader is not replaceable unless you replace the entire motherboard as it is soldered onto motherboard itself. Easier solution is to buy a portable, USB 2.0 or 3.0 multi-card reader.
Eric tarafından
