What I suspect happened here is you had laid something heavy on top of your air so the logo disk in the lid embossed the defuser sheets. So what you see is the light from the backlight (really on the upper & lower edge) being distorted by the damage.
Sadly, this is not an easy repair. Most people have found they end up making it worse! I would live with it, or think about finding a used display assembly to replace yours.
Yes, this is the light source for the screen (Back Light).
No it won't get worse as ling as you don't put something heavy on the lid again. Frankly, you were lucky here! More often the screen gets damaged (black or color bars).
As for altering the brightness it may help to make it less noticeable. But that will only go so far.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
3
5 Comments
Can you post a picture? You have to edit your original question and add it there.
Rany tarafından
Also can you give us the last four digits of your serial number so we can correctly identify which model you have. Apple has made quite a few different versions of this system.
Dan tarafından
ddr1 are the last four
Ross tarafından
sorry for the poor quality pic but it only shows on a photo on a white screen and on an angle
Ross tarafından
MacBook Air 13" Core 2 Duo 1.86 GHz (Late '10)
Dan tarafından
