Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Soru Kapandı
iPhone 5s drains quickly even without using it
Why is my iphone 5s drains quickly even after replacement? Can anyone help me for this? It doesnt last overnight even without using it. I turn off the 3g and close all the apps. But it doesnt work for me.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I take it you replaced the battery? Did you get it from iFixit or somewhere else? There are a lot of poor quality batteries around but it's worth paying the extra for an iFixit one.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
If replacing the battery from a reputed seller like iFixit doesn't fix this, you could have a board issue.
Most common board issue is the U2 / USB IC being defective. This makes the phone burn through the battery very quickly, and other symptoms such as the iPhone is not detected by iTunes and/or when the battery is completely drained, it will not recharge back although the symbol on the screen will say "charging."
Other causes: poor reception causing high power consumption; OR during previous repair(s) some parts where omitted, causing the phone to have poor reception and again drain more power; OR short in some parts of the board, using up the power (must be overheating); etc.
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 156
