Why is my touchscreen not working?
My screen is on but my touchscreen won't work.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Depending on the reason there are a couple of different solutions. If the screen is frozen, it will need to be rebooted. Either by holding the power button down for 10 seconds, or the power button and "volume down" button at the same time for 10 seconds. After it restarts, the touchscreen should be working. If it's still not working, the digitizer may need to be replaced. You can find the steps in more detail on the troubleshooting page
Bu yanıt yardımcı oldu mu?
touch ic replace
Happens on mine after blue tooth mouse has been connected. OK after reboot
Try rebooting or if that doesn't work a reset Hold power button and volume down button together for 10 seconds. If these did not work there is a chance you damaged the digitizer if the tablet was droped or suffered a blow of some sort.
you going service senter
Mine did this I just slapped it till the digitizer went back and it worked and still does 2 yrs later
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 16,464
1 Yorum
1. touch check
2. touch ic replace
Sufiyan puthanathani tarafından
