Ana içeriğe geç
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Soru Tümünü görüntüle
Missing solder pad on Touch screen connector iPad mini 2
Hi guys,
We have a problem.
A customer brought an iPad 2 mini. I disassembled ipad, and I realized the touch screen connector was damaged. I removed the connector with solder iron, but one of the solder pad are missing.
what is the solution ?
thanks
Tibor
picture:
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
This is all wrong !!! The missing pad is 5th pad !! 5 NC - no connection !!
Yellow selection is pad 6,
oldturkey :D
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
@fixlab excellent job in finding this. Amazingly enough it took a year for somebody to catch this error. I did correct the original answer.
tarafından
No problem ;)
tarafından
@fixlab I have the same problem. The pads number 5, 15, and 17 are missing. Colud you help me with the schematic picture? Where could I connect the missing pads? Thanks!
tarafından
gabor, pin 5 is nc, pin 15 is ground and 17 you can connect to the large cap to the left side of the connector. on the right side of the cap
tarafından
Thank you daniel!
tarafından
2 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
Iphoneszerviz Szeged, correction. That is contact #5 of J1700. It does not need anything. NC no connection
Puan 6
6 Yorum:
Very useful, Thank you!
tarafından
By placing a jumper from the cable to the board?
tarafından
thank you old turkey, :)
tarafından
@oldturkey03 extremely grateful!
tarafından
@iphoneszerviz, did you manage to repair this? Can u post a pic or explain a little what you had to do exactly? We are facing a similar prblem ourselves with the exact same pad ripped off during a connector replacement
tarafından
1 tane daha yorum göster
Yorum Ekle
try to use best or recommended rework tools when you touching high tech logic boards. Here i can see one path Path damaged on your logic board.
you have two options,
1) Change the new logic board
2) Path modification : check the path destination and you may have to connect them physically
All the best!
Puan 2
3 Yorum:
circuity diagram available this iPad?
tarafından
creativeelectron (http://creativeelectron.com/) seeking your support to find path of 8th contact - TP
tarafından
jessabethany, seeking your support as well
tarafından
Yorum Ekle
Yanıtını ekle
Iphoneszerviz Szeged sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 4,735
