Ana içeriğe geç
The Nikon D5200 is an F-mount DSLR camera with a 24.1 megapixel DX-format CMOS image sensor. The D5200 has a maximum resolution of 6000x4000 and is capable of 1080p video recording.
20 Soru Tümünü görüntüle
How do I fix a stuck lens?
My camera lens is stuck. Is there any way I can fix this on my own?
Bu iyi bir soru mu?
Puan 2
1 Yorum
I cleaned it with paper worked great
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Stuck lenses are a common problem. Usually, it's caused by sand or dirt inside the mechanism, or the lens has been dropped. Sometimes, you can't repair it yourself and you will need to take it into a repair shop. However, you can first follow the steps in this guide to see if you can fix it yourself.
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
If you r lesn has fallen and as a result is stuck, I have found on YT a totrial that can help. It has worked for me and saved me quite an expensive repair. I ahve copied teh title and link to the video below, good luck:
HOW TO Repair A DSLR Camera Lens That Is Crooked And Jammed After Being Dropped #DIY #Repair
https://www.youtube.com/watch?v=_4K1Ge5C...
Puan 0
Yorum Ekle
Yanıtını ekle
Alexander Corn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 93
Her zaman: 43,223
