Ana içeriğe geç
This is the first generation of Amazon Fire TV (model CL1130), released on April 2, 2014. It is a powerful media streaming and gaming device that allows the user to stream digital audio/video content to a high-definition television as well as play video games.
32 Soru Tümünü görüntüle
Why can’t I get internet access with a wired Ethernet cable?
When I try to connect to the internet using a wired Ethernet cable connection, the Amazon Fire TV will act as if there is no internet connection. What can I do to fix this problem?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
There could be a couple reasons for the Internet connectivity problems. Maybe the Ethernet cable is not correctly connected, or the router is not providing Internet access. Maybe it's also a hardware problem, in which the Ethernet input port may be damaged. For more information, visit
Amazon Fire TV Troubleshooting
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
useless information. how is this solved ?
tarafından
I use the Amazon Cube 2nd Gen. When I connect ethernet Have to cut off Wi-Fi The problem that I have I cannot use my Amazon echo's Because when I cut off the Wi-Fi on Amazon cube It disable everything else So I have to use either or
tarafından
Hasn't solved my problem must be problem with new fire stick
tarafından
Yorum Ekle
Why won't my internet is not working what is going I have xfined
Puan 0
Yorum Ekle
Yanıtını ekle
cory burke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 14,317
