Ana içeriğe geç
Find repair information on the second generation Toyota Tacoma.
20 Soru Tümünü görüntüle
How to change running light bulbs
Change burned light bulb. How to access old bulb to put in new.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Are you referring to the amber turn signal bulb or the small bulb in the corner of the headlight? If so both of those bulbs can be easily accessed if you open the hood and reach around the backside of the headlight. There you can twist the socket to the right and pull the bulb out and replace them without removing the headlight entirely.
Turn Signal/Running Light Bulb Type: 4157NA
Small Side Marker Bulb Type: T10
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
You can pry the plug off easily using a screwdriver between it and the housing. The bulb holder is a different story in it can be just a hard to turn object without a size a socket can cover. Careful with pliers to not break the plastic.
tarafından
Yorum Ekle
Yanıtını ekle
Tim Blackwood sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 45
Her zaman: 3,939
