Ana içeriğe geç
Repair and disassembly guides for Brother printers.
unable to print 51
Brother MFC-665cw
what does unable to print 51 means
Bu iyi bir soru mu?
Puan 3
1 Yorum
Thanks...unfortunately, the dinosaur was not able to be fixed. Tried all suggestions and finally took it to a professional and they told me it wasn't worth the cost to try and repair.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi
the following link may provide the answer.
https://www.easyink.co.nz/support/brothe...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
SOLVED
It worked!!! Thank you!
tarafından
Yorum Ekle
En Yararlı Yanıt
Machine off
- Switch on the machine while holding down the "Menu" button, until all the leds are flashing on/off: it's the "maintenance" mode.
- Press 80
- Press the "Mono start" button several times until you see "purge: xxxx"
- Press "2783" in order to reset the purge counter. You will see: "purge:0000"
- Press the "Stop" button.
- Press "99" to exit the maintenance mode.
This may or may not work but it's worth a shot.
Puan 3
2 Yorum:
tarafından
This worked for me, thanks!!
tarafından
Yorum Ekle
Yanıtını ekle
Camely Medina sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 18,874
