Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Soru Tümünü görüntüle
Rear Camera Lens Cover
My rear camera lens cover is scratched. I removed the lens cover by taking off the back panel. Where can i get a replacement lens cover for the rear camera?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi
I would disagree. I have just replaced the rear camera lens cover on an iPhone4, by buying a replacement lens cover ( the small circular ring shape) from the internet. Cost was around £3. Fitting it was easy, but bear in mind that the original is glued in place. Also, if you get a replacement, there is a plastic film over the inside (back) of the cover, which will need removing, unless you like all your photos to have that romantic fuzzy look.
New cover is now on and a great improvement over the previous scratched cover.
Bu yanıt yardımcı oldu mu?
Puan 5
3 Yorum:
Can someone tell me where can i get the back camera lense glass? Can't find it anywhere :(
tarafından
This place sells the back camera cover, see if it works for you, I'll probably be ordering it soon.
http://www.miniinthebox.com/back-camera-...
tarafından
Here's another source for the lens cover:
https://www.etechparts.com/iPhone-4-Came...
tarafından
Yorum Ekle
After you open the phone simply use your thumbnails on the lens cover and push firmly -- the glue will give way. Be careful not to scratch the black by trying to pry it with a screwdriver.
Puan 2
Yorum Ekle
Yup, glued into place but replaceable - some more-so than others. Worth a shot before replace the whole back in my opinion. Changed it a couple times with just a little force and the #*% of a sharpie.
Puan 1
Yorum Ekle
I can confirm the lens is easily popped out with minimal force from the back or inside once the back panel is removed from the phone. I don't think it was glued. I popped one out of a relatively new but broken back panel I was replacing and popped it into a used panel I had that had a more scratched lens. I just pushed out onto the bench with a spudger and then pressed the other panel onto it, so no fingerprints were put on it.
Puan 1
Yorum Ekle
Hi Scott, I'd reference this answer that I wrote to a similar question.
Hope this helps!
Puan 0
2 Yorum:
Where can I purchase the back that includes the lens cover?
tarafından
Please read the other answer I linked in my answer here. Here's the link to it: Where to order a back panel for my iPhone 4? Unfortunately I can't give more details yet on we will have the rear panel for sale.
tarafından
Yorum Ekle
Yanıtını ekle
scott Fata sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 36,904
