engine dies when throttle applied
Why does my engine snuff out when I apply the throttle
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Possibility it may have old gas or some water in fuel.change in-tank filter and adjust mixture jet located (opposite side of throttle cable a hole with small flat head screw). Play with it a quarter turn in either direction to see any changes.our echo techs say they call it bubbling. A unique sound youll know right away when you get it adjusted right. Do this at idle. If the adjustment brings the idle up no worries turn down the idle screw at the top of carb.good luck
Bu yanıt yardımcı oldu mu?
I have had this problem too. Mine was too much carbon build up. I took the muffler off and used a propane torch to clean the screen and the inside of the muffler.
Son 24 Saat: 8
Son 7 gün: 94
Son 30 gün: 312
Her zaman: 16,427
