Ana içeriğe geç
Repair guides and troubleshooting for the Acer Aspire 5750. This is a 2012 Aspire budget laptop aimed at the casual household user or for small business use.
26 Soru Tümünü görüntüle
Soru Kapandı
Acer aspire 5750G Booting problem/disc read error
Hi. Hope to get some help.
I was transfering files (movies, not system files or something) from C to D on my computer, because C was almoust full. Then suddenly my pc turned of. When started, the error message "No bootable device - insert boot disk and press any key " showed up. (Plus some text before that, which I dosen't remember.) Pushing any key or restarting my computer didn't help.
I tried finding a solution online and someone said I should take out and put in again the hard drive. I did this, which resulted in the computer recognising the hard drive. (I am pretty sure it used to say that it didn't recognise it/none, when I pushed F2 when starting the machine, but now it does recognise it.)
Quite soon after this (I might have looked at F2 once or twice more, without doing anyting in there) the error message changed to "A disk error occured. Press Ctrl+Alt+Delete to restart." This obviously doesn't help; the message just pops up after the restart.
So please help :) The computer is not very good, so I don't want to send it to repair just to pay a lot of money. The repair probably will just erase all my pictures and videos as well, so I don't like the idea of that.
Thanks for the help you can give me :)
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
"Google" how to install HDD from dead laptop into another PC. If your HDD is still OK this will allow you to recover all your files before you attempt to repair your laptop.
Once you have recovered your files you can re install the HDD into your laptop and then you can troubleshoot your problem.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,004
