Spilled Water on PS3 Controller
i spilt water on my ps3 controller and my L2 button stopped working, is there any way to fix it? or do i have to buy a new controller
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It sounds like there may be a short on the input board. Check out this guide for access. Check for corrosion or other signs of damage. Using some rubbing alcohol, clean the contacts. If there is a large amount of corrosion, you can use some steel wool to try and get rid of it.
Good luck, and let us know how it works out.
Bu yanıt yardımcı oldu mu?
Make sure if you use steel wool you clean thoroughly to remove any steel particles. +
you could get a new L2 peice
Give more info on the L2 piece. Exactly what is it referring to?
its reffering to the L2 button
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 8,441
