help me clear error 46
i am having a problem and my all in one is saying error 46 help me to repair
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Machine Error 46, Purged Ink Box Full
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An initial purge, for example, advances the purge counter by 187 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unusable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: unplug the unit, hold down the Menu/Set key, re-insert the power plug while holding down the Menu/Set key. The internal Machine Error Code will be displayed. Unplug and re-plug the unit again before continuing to the steps below.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter:
Bu yanıt yardımcı oldu mu?
This answer was incorrect for Brother MFC-3240c.
Then post your own solution if you're able to fix it!
Any clues as to how to dismantle the printer?
Don Minow
dminow@comcast.net
Printer is a Brother 490CW using LC65 black cartridge/LC60 color.
All you have to do before purging counter, you clean all silicon hose for dispense ink absorber and clean the absorber respectively.
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 15,706
