How do you calibrate the screen?
When I try to tap my screen it'll select something else
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Check if there is a Touch and Hold Delay setting in your phone. If there is, set the option to short.
To find Touch and Hold settings, go to:
Menu > Settings > Accessibility > Touch and Hold
Bu yanıt yardımcı oldu mu?
I already tried that, it didn't help.
Hi,
As a test, rotate your phone 90 degrees (so that it is in landscape mode) and see if you have the same problem. It may be an area of the digitizer that is faulty. Alternatively, backup your phone and perform a hard reset. This should restore your phone to factory default condition.
I tried to reset and everything still doing the same thing might be calibrate I have not try it yet
I got problem with my phone as well done everything but! No change with key pad?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 9,104
