Ana içeriğe geç
Improved second generation Google-branded tablet with a 7" screen.
Nexus 7 Device Charging Help
Device stopped charging. Replaced charging port and still wont charge. Lock screen does not indicate charging. Tried multiple chargers. Replaced battery and conditions remain the same.
Any advice?
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Check you cable try a different usb charger some times the block from asus goes bad and would need replacing
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I have tried multiple chargers. Ones that work in other devices and it has no effect.
Thanks
tarafından
Yorum Ekle
the asus brick not the cable
Puan 0
3 Yorum:
I no longer have an asus charger brick or cable. I have two other Nexus 7s and they charge with these other chargers. Can I even buy an Asus charger at this point? Should I try that?
tarafından
yes ebay carries them cheap
tarafından
asus sells the bricks with them because of certain amperage needed to charge the tablet not every tablet take the same amperage
tarafından
Yorum Ekle
Yanıtını ekle
pmcint01 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 136
