MacBook Pro wont power on after hard drive replacement
Good day
i replaced my stock macbook hard drive with samsung 850 evo ssd.
i followed thr ifixit manual; removed the back cover, removed the battery point from the board, replaced the hard drive and reattached the battery pin on the board.
After that i tried powering on my system, but it wont power on.
I Tried everything, clearing my PRAM, resetting SMC, reinstalling the old hard drive but the system wont power on.
I removed the back cover again and pressed the battery pin on the board, making sure it wasnt causing me trouble, but it was well intact.
I Would appeeciate help here! Been hours i am trying to bring my macbook to life!
MacBook Pro, OS X Yosemite (10.10.5)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
What does the battery test button show? What is the light on your mag-safe adapter indicating?
tarafından
Magsafe light is very dim green.
The battery test indicator isn't showing up at all.
tarafından
You have a short to ground. What that means is something is making contact where it shouldn't. A test you can try... Leave the cover off the bottom of the laptop. Set it on a non conductive surface, and turn it on with the power connected. If it turns on, something between the keyboard and the bottom of the case is shorting to ground.
tarafından
Yorum Ekle
