Ana içeriğe geç
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
20 Soru Tümünü görüntüle
Wont start after replacing starter solanoid assembly
I have a 1991 honda accord ls automatic. Replaced the starter solanoid assembly (all in one piece) after trying to start the car and got nothing but "click,click,click" when turning the key to the start position. Still had that issue when i replaced it, my grandfather "jumped" the starter (as he called it) by using a screw driver to connect the wire that goes from the key in the ifnition to the other wire, it made a really loud grinding noise and started after that, we let the car run for a few minutes then shut it off to try and start it again, "click click click" so he did it again. Anyways, now we cant get it to start even when doing that. I think my grandfather fried the starter doing that. What can i do to figure out what is causing this? And yes i checked the battery.
Bu iyi bir soru mu?
Puan 0
1 Yorum
Similar Problem. New stater. checked all cables, seems ok and new battery. At time it start at times its just a click, and does not start or takes a few seconds then starts while i hold the key on
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Go back to basics - check that battery, cables, and connection are all good. If so, then replace the solenoid again (make sure you are using a NEW solenoid, the high current contacts in the solenoid are the primary failure point in almost all nippon-denso starters). Do not assume that the battery is good just because no-load voltage is OK, please test that voltage does not drop below 9v when a 300 amp load is applied.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Oops i should have taken this down. We did exactly what you said. Replaced the starter again and then had the battery load tested and it failed so we bought a new battery too. After spending a couple hours putting it all back we got the dang car to start right up. Thank you!
tarafından
I did this, and my car still won't start, the light bearly come on, acting like it's a dead battery...
tarafından
I replaced my starter sylnoid and it still click click click. But after a little bit the car starts. Even after the new starter assembly. I'm confused as heck
tarafından
The starter needs quite a bit of electrical power, make sure the battery is fully charged and load tested. Make sure the battery cables are clean and tight at both ends. Make sure the solenoid receives something very close to battery voltage when the key is turned to the start position. If those 3 are true and the battery voltage under load (about 200 amp test load) stays above 9v you should be OK.
If the battery fails a load test, replace it.
If the cables have any corrosion or are loose, clean or replace them as necessary.
If the trigger voltage to the solenoid is dropping, it could be the ign switch, or a safety switch or relay that is sitting between the ign switch and solenoid.
If none of the above, you may have gotten a dud starter... try bench testing it.
In the Jamesbevins18 case, I think ign switch with marginal start contact is quite possible.
Also note that you can kill ign switches pretty quickly by hanging ten pound key rings off of them.
tarafından
Yorum Ekle
changed starter it started a few times after new starter then it doesn't start makes a grinding sound then goes to a click
Puan 0
Yorum Ekle
remember when you install a new starter or batter LET THE CAR RUN FOR AT LEAST 30 minutes….Mechanics don’t want you to know this.
Puan -1
1 Yorum:
Unless you just installed a "new" almost dead battery, this will only waste gas.
tarafından
Yorum Ekle
Yanıtını ekle
Nicole Krauth sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 30,111
