My phone does not turn on
my phone does not turn on. it only shows continuously
"Samsung galaxy A3 powered by android" even after removing my nano-sim and
thanks
Alina
Bu iyi bir soru mu?
thanks
Alina
Bu iyi bir soru mu?
Press and hold the Volume Up, Home and Power buttons.When you see the Galaxy logo release only the Power button. then when you see the android system recover release the buttons . Then select reboot system ,now use the power button to select it. If it doesn't work let us know
Bu yanıt yardımcı oldu mu?
I try it but power dead still
I tried but it did not turn on but it said " WARNING.
a custom OS can cause critical problems in phone and installed applications.
if you want to download custom OS, press the volume up key.
otherwise, press the volume down key to cancel."
Then i press the volume key down, it blacks out, then i repeat this routine for a few times, it does the same thing over and over again.
For my samsung A5 (2017) worked to hold volum down and power buttons
my samsung a5 2016 was not working properly and sensor was also not working ok. then i restarted the mobile and it went custom OS can cause critical problems in phone and installed applications.
i did the same but still not working , now i am charging it for the last 1 and half hours still giving sign of battry temperature low please help me please
i was using my phone (Samsung A-5 2016 edition) and suddenly it turned off and now its been 2 hours its not turning on
Nothing worked , tried the instructions ,but it's no use.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 13,753
