Ana içeriğe geç
APEX TM785CH, TMAX Technologies tarafından üretilen 7,85 inçlik bir dijital tablettir. Bu tablet 16 GB depolama alanına sahiptir ve dahili WiFi içerir.
it not powering on
will not turn on. it is plugged into charger but not powering on
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Do you get an indication that it is charging when you plug the charger in?
If no:
Have you tried connecting your tablet to a working PC USB port and see if you then get a charging indication?
If yes, allow the battery to fully charge and try turning on your tablet. Your charger will need replacing.
If no, try a different USB cable and see if it you get a charging indication.
If yes, allow the battery to fully charge and try turning on your tablet, your cable will need replacing, retry your charger to see if it works with the new cable.
If no, the charging circuit and /or the battery in your tablet is faulty
If yes:
Try a hard reset.
Perform a factory hard reset by pressing and holding the volume up + volume down + power buttons. Release when the device restarts.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
first9032 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 477
