Ana içeriğe geç
Mitsubishi Motors Corporation tarafından üretilen otomobil ve SUV modelleri için onarım rehberleri ve destek.
How to wire a push button horn? 2002 Lancer
My horn is gone in the steering wheel so while I save up to get it fixed I need a horn in the meantime.
So i have a button and two wires positive and negative.
Someone told me positive from the switch to the horn and negative from switch to batery, but it didn't work. Cos apparently the horn is always grounded.
There is power running to the horn.
Any help is greatly appriciated I have been trying for two months.
Thanks
Bu iyi bir soru mu?
Puan 1
3 Yorum
Oh thanks ppl I'm going to try these except how do I test to see if it is broken?
Thanks
tarafından
Connect a multimeter to the horn relay. When you push the horn button you should see that the relay gets excited and closes the contacts to the horn. Do you know where the relay is and do you have a meter?
tarafından
No idea wat a multimeter is so probs so r have one.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
you may want to test the horn to see if its ok you may not have a bad switch you may have a bad horn
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
By the way the horn is grounded and only needs power. to your switch run a positive and from there run a wire to your horn
tarafından
Oh that sounds easy I'm gona try this. If this wrks ur a genious
tarafından
Yorum Ekle
En Yararlı Yanıt
You need to wire in a relay. The switch will not carry the current needed. Run positive from the switch to terminal 85 on the relay. Ground the switch to the body near the switch. Run a wire from terminal 86 to ground (negative). Run battery power into terminal 87 on the relay and run from terminal 30 to the horn.
Resim
Puan 2
Yorum Ekle
Hi,
If the horn button on the steering wheel is not literally broken have you checked that the horn fuse and horn relay are both OK.
Resim
Resim
This shows the location of the horn relay.
Puan 2
2 Yorum:
I may be considered over the hill but I can still read small print, but this is ridiculous. Make it LARGER so that we can read it without a Magnifying
glass. Please.
tarafından
@Peter Rushbrook
If you hover the cursor over the image there is a magnifying glass symbol. Click on that and the image enlarges. Click on the enlarged image and it enlarges even further.
Moderator
tarafından
Yorum Ekle
Yanıtını ekle
Sarah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 15,296
