Ana içeriğe geç
Dahili Beats Audio™ özelliği; müzikleriniz, videolarınız ve oyunlarınız için tavizsiz, stüdyo kalitesinde ses sunar. Çift çekirdekli gücü, parlak ve net dört inçlik ekranı ve sınıfının lideri kamerasıyla aynı zamanda güçlü ve çok yönlü bir performans sergiler.
Cannot get the phone to start
My HTC Desire pay as you go phone has suddenly gone blank. No screen, nothing. I am away on holiday and rely on this to call my elderly mother. Any advice welcome.
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi,
Do you get any indication (charge light, symbol etc) at all on the phone when you connect the charger to the phone or if you connect the phone to a USB port in a working PC? Can you try a different compatible charger or USB cable?
tarafından
No indication at all. Cannot connect to PC but have tried 2 chargers.
tarafından
Yorum Ekle
0 Cevap
Seçilen Çözüm
Hi,
Try the following:
Remove the battery, wait for about 10 seconds, then reinsert the battery.
Here is a video that shows how to remove the battery. The battery only has connections at one end so when you replace it make sure the terminals are in the correct position. Also don't miss it in the video the battery removal is complete within the first 27 seconds .
See if it will charge/start now.
If not try performing a factory reset.
Be aware a factory reset will erase all your downloaded apps and user data . It will restore your phone to a factory default condition. It will be like when you first bought it.
To reset your phone:
  1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
  2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
  3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Be patient, it takes a few minutes.
If you cannot perform a factory reset due to the phone not responding, unfortunately and obviously the phone is faulty. Perhaps a professional phone repair service may be able to repair it. Ask for a quote first.
If your phone is still under warranty, contact the manufacturer's customer service section regarding a warranty replacement.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Thanks, removing the battery worked!
tarafından
Yorum Ekle
Yanıtını ekle
Hilary Patterson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 393
