Where are the power pads to short it on?
I’m looking for the pads to touch to short it on to check to see if my keyboard is broken.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
David Molinari you can do this by either shortening pin 5 of the keyboard connector briefly to ground. You can also use the debug pads as pointed out.
Bu yanıt yardımcı oldu mu?
Thank you very Much oldturkey03!
Hey! When I short the two pads it turns on but the fan goes on at full speed and doesn't stop. Where is keyboard connector 5 by the way? Thanks in advanced!
Hi, thank you so much!!!! I've been searching these power-on pads for so long...
I "only" have to replace the keyboard now.
Must i disconnect the keyboard in order to power up with power pads ?
francoisvdc no you do not.
Son 24 Saat: 5
Son 7 gün: 12
Son 30 gün: 55
Her zaman: 22,781
