Ana içeriğe geç
13.3" flip-top, touchscreen laptop (SVF13NA1UL).
17 Soru Tümünü görüntüle
Display blink, problem with intel graphic driver
I try update to new driver, i try roll back old driver, but display still blinking. Only work when graphic card is disabled, but then brightness control dont work, and battery life is only 30 mins. Any fix?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum:
Everyone says is only driver? If conctor is broken, display will not work when i disable drivers?!
tarafından
nastic, exactly what do you mean by blinking? Does it do it all the time? It stops blinking when you disable the graphic card? How do you do that? What do you get when you connect an external monitor?
tarafından
does the problem happen when the battery is connected? I would look for info on how to do a power flush on the laptop, I'm looking but can't find anything. this has fixed issues like this for Dell machines in my experience.
Sony Vaio Fit 13A Troubleshooting
tarafından
@oldturkey03 i just disable from device manager. Its happend in both ways, on battery or cable
tarafından
This is exactly what i am experiencing now, did you find any solutions?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hello Nastic
Im my opinion by what you wrote the display conector inside your Laptop are probably damaged from the inside and the battery that means its damaged or the laptop is not getting the voltage that it needs
HOPE THIS HELPS :D
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
It works when the GPU is disabled.
tarafından
Yorum Ekle
Yanıtını ekle
nastic sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 18
Her zaman: 1,428
