How do I wire a tachometer
how do i wire a tachometer on a 1993 jeep grand cherokee
Bu iyi bir soru mu?
Bu iyi bir soru mu?
jimmiller1940, as a general answer since we do not know which tach you have, most aftermarket tachometers only have 3 or 4 wires that need to be connected. Usually a green wire for the tach, red for power, black for ground, and white or yellow for the back light. The power wire that gets connected to a 12 volt ignition source, the tach signal wire that connects to the coil or the designated signal wire in your cars wiring diagram.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 1,354
1 Yorum
what make and model is your Tach? Post some images of the connectors with your question. Use this guide Mevcut bir soruya görsel ekleme for that
oldturkey03 tarafından
