Ana içeriğe geç
HP Parça No: CN731A#B1H: Yazıcı, tarayıcı, fotokopi, kablosuz internet özellikli web tarayıcısı
Why will it not make a copy?
Copy icon highlighted, I press ok, It prompts me to choose color, b & w or economy. I scroll to B & W and press ok. Number of copies comes up with a 1 in the field. I press ok. Display screen returns to the first screen... It does this no matter what choices I select. I have removed and reinstalled the ink cartridges. Has anyone seen this and resolved this problem?
Thanks,
Jim s.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Check that both the ink cartridges are not low. The printer will not copy if the cartridges are low.
If they are alright try a semi-full reset and see if it resolves your problem.
Touch the upper left corner of the touch pad once, then the upper right corner, then the upper left again two times. "Support Menu" comes on screen. Hit the right arrow to "Resets Menu", then the right arrow again to Semi-Full Reset".
Be patient it takes a little while.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
James Sexton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 747
