Ana içeriğe geç
Can be identified by Serial Number: 31.2000.2338851 Manufactured by Keurig
18 Soru Tümünü görüntüle
Water or coffee is dispensing slowly
The water or coffee is not following freely. It is pouring slowly into the cup.
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
if the water or coffee are pouring slowly then the top needle may not be sufficiently penetrating the K-Cup. Beside that, you need to clean or sharpen the needle.
If the needle is fine, then you need to check on the hose. It maybe partially clogged.
troubleshooting
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I also have this problem but all the water and air tubes/passages are clear of obstructions, there are no kinks in any of the tubing and the air pump works fine.
The coffee brews but the water discharge into the cup is very slow and weak compared to when the K10 was new
tarafından
Yorum Ekle
Yanıtını ekle
Roberto Maldonado sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,890
