Ana içeriğe geç
A business-class notebook with a 13.3" touchscreen display.
How can I replace my LCD Screen?
My screen recently broke, it refuses to turn on. I read through the tear down and was unable to determine what I should do in order to replace the screen.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Mitch,
Try taking a look at the LCD replacement guides for similar models. The HP EliteBook 8440p has a LCD replacement guide and so does the HP EliteBook 6030p. You can also find a replacement part on Amazon. The replacement LCD for your laptop can be found here. Be sure to double check your model numbers to be sure you've ordered the correct part. Good luck!
HP Elitebook 6930p Display Assembly Görseli
Kılavuz
Removing the HP Elitebook 6930p Display Assembly
Zorluk:
Orta
45 minutes
HP EliteBook 8440p LCD Görseli
Kılavuz
HP EliteBook 8440p LCD Replacement
Zorluk:
Kolay
20 - 30 minutes
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mitch Kev sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 2,833
