Ana içeriğe geç
The Sony Handycam HDR-CX380 was released January 2013 and is identified by the model name HDR-CX380, HDR-CX380/B, HDRCX380, HDRCX380/B, or HDRCX380BBDL.
Why won’t my camera focus?
Even though I am taking pictures in a well-lit area, I still can't get the camera to focus on the subject. I made sure that the autofocus was set to on and tried taking the pictures from various distances.
Bu iyi bir soru mu?
Puan 3
1 Yorum
How much is this going to cost me?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The problem is likely an issue with the lens. The lens may be damaged or dirty. In order to clean the lens, you will need a lens cleaning solution and a lens tissue. Simply apply a few drops of the solution to the cloth and then gently rub the lens with it. This should remove any dirt, fingerprints, or grime. If that doesn’t help, you can try rebooting the camera by turning it off, removing the battery for about 6 seconds, and then reinserting the battery and turning it back on. If you are still having difficulty, and if the lens has visible damage, you will need to replace it. For more information, take a look at the troubleshooting page for the camera.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It won't focus. The focus indicater stays in middle or moves to left only.
Puan 0
Yorum Ekle
Yanıtını ekle
John Santoro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 6,064
