Is the HTC One M8 battery same as the M9 one?
I've looked at both batteries, same capacity, same size and plug. Aren't they both essentially the same battery?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I've replaced today the battery of my HTC M8 and found in my phone the 2840 mAh battery.
It's the first replacement, since i bought it in 2016.
Also both batterys working fine.
Bu yanıt yardımcı oldu mu?
Yeah, I did the same thing as well too. Works great. Looks like their interchangeable.
Hi Ben,
If I was going to nitpick, the official specs for the M9 is a 2840 mAH battery and the M8 is a 2600mAH battery but yes essentially they are the same in every other aspect.
Okay, they are both physically the same in size, yet somehow they managed to squeeze more capacity.
did u try it guys to replace m8 battery with m9 battery if yes and if it worked reply me please on lashuuka@gmail.com thanks .
the battery can fit in either one and it is compatible without damaging your phone
I can tell you, from experience, the HTC One M9 and the HTC One M9+ have the same battery.
The m9 battery is 3.83v,2860mah,m8 is 3.8v,2600mah. May be it can work well after change but you'd better not do this for safety.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 2,944
1 Yorum
Hi Ben I look at the image of both batteries and I also think they are the same.
Mimi tarafından
