Why is my picture too exposed?
When I shoot outdoors, my picture is too exposed.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Most likely, the camera is in the wrong mode.
For daylight outdoors shooting, set the mode dial to AUTO. If the images still turn out too bright, check the ISO setting: press the ISO button and make sure it's set to AUTO.
Another reason why the images may appear excessively bright, is the LCD brightness setting. If the LCD brightness is set to Bright, images may appear brighter than they really are when you view them on the camera's monitor. Setting the LCD brightness to Bright makes sense when you're viewing your images outdoors in bright sunlight, but otherwise it's best to leave the LCD brightness set to Normal. Press the MENU button, select the Set Up menu, and check the LCD Brightness setting.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 16
Her zaman: 1,646
