Ana içeriğe geç
Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
Why is my device not printing correctly?
When I try to print out a label, the label maker doesn't print correctly.
Bu iyi bir soru mu?
Puan 1
2 Yorum
I have this printer and when i am getting prints labels come little bit yellow to brown colored repeatedly/exactly at the same time. What could be the problem?
tarafından
the print is not legible. and I have the LetraTag
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check to make sure nothing is obstructing the printing area, then make sure your cassette inside the label maker is correctly aligned and pushed all the way down into the compartment. If problem persists, follow the link below to the troubleshooting page.
Dymo LabelManager160 Troubleshooting
Bu yanıt yardımcı oldu mu?
Puan 4
10 Yorum:
For others that have this issue, I was having the issue as well. For me, it was weak batteries causing the ribbon not to print/advance even though the winding motor was turning.
tarafından
I tested all batteries with a battery tester! All batteries were well up into the green! Just for the heck of it I changed all the batteries! Voila! Problem solved, just as Dave stated. Funny how the unit needs so much power! I'll save the original batteries for another use!
tarafından
in absolute disbelieve worked for me too!! even though I changed the battery I switched from Kirkland brand to Duracell and I have printed labels. I had exact the same situation as Dave
tarafından
@Dave Pope It finally came alive for me after trying my 3rd set of brand new batteries. Thank you for the post.
tarafından
I had the same problem. Replaced the batteries. Works fine. Like others have said why does it need new if not almost new batteries to print. Oh well.
tarafından
5 tane daha yorum göster
Yorum Ekle
Home & Hobby III P-touch printer stopped printing. Motor works.
Puan 0
1 Yorum:
I have it hooked up to a power pack and it's not printing. It just prints the sticker. ??????
tarafından
Yorum Ekle
so the battery thing is not working for me... there are still no letters printing on the tape and by this point now i almsot out of tape just trouble shooting the darn device.
Puan 0
Yorum Ekle
The print head is not moving but the sprocket does when I press the insertion detection https://help.dymo.com/s/article/How-do-I...
Puan 0
Yorum Ekle
Yanıtını ekle
Nathan Friedman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 66
Her zaman: 91,611
