Ana içeriğe geç
Üzerinde oturulan çim biçme makinesi. Sıfır dönüş yarıçaplı biçme makinesi, 50 inçlik biçme tablası, hidrostatik şanzıman.
mower starts but will not engage in forward or reverse
My mower will not go forward or in reverse when moving the levers forward or backward. No symptons could be detected prior to the issue. I was mowing and starting to go in reverse and it would not go. At that time it would not go forward either.
Bu iyi bir soru mu?
Puan 12
4 Yorum
broken drive belt
tarafından
how do you replace it.
tarafından
i had a broken belt spring at the back of my Z-726X that controls going forward and backwards. Easy fix.
tarafından
I have the same problem, under seat i not sure where the tensioner spring hooks to? The frame to pully or some where else. Plz
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would replace the drive belt. Instructions will be in your manual. I attached an image of the instructions and the belt routing. The manual is available online at http://www.hammerwall.com/Download_Manua... little bit of an odd site, but it works :-)
Resim
Good Luck
Bu yanıt yardımcı oldu mu?
Puan 4
13 Yorum:
Checked belt, it's not broken, what else can it be
tarafından
May Thigpen same mower? Same model? Same problem? what does it do? What have you checked?
tarafından
my wife found a spring under the back of the mower when this happened to us. connection?
tarafından
I am having the same problem the bottom pulley in the back does not turn the upper seems to turn, there was a ringing noise right before it started to act up. JH
tarafından
Jesse Hubbart same mower same setup? What upper and lower pulley? The ones on the drive?
tarafından
8 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Danny sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 33
Son 30 gün: 78
Her zaman: 104,093
