Ana içeriğe geç
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
After replacing my screen I have had ghosting problems
So several months ago I had dropped my onePlus one and cracked my screen loosing all touch capabilities on the bottom 2/3 of the screen. After getting by using a microUSB mouse I decided the best solution for me was to fixit my self thanks to this website. I was able to successfully replace the screen and didn't have any problems with my phone for several months. However, over the past 2 months it has began to have a very annoying Ghosting problem that seems to come and go but has gotten bad enough I have had to apologize for phone calls I didn't make and delete pictures I didn't take. From my research and experience on the issue I'm still uncertain if this is a hardware or software issue. It does seem to be worse if my phone is hot from intense use or very visually intense apps but that is the only clear connection I have seen. Any advice on how to resolve or troubleshoot the issue is welcome and appreciated. Thanks for you help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
I have the same issue, But i want to try replacing the screen again this time with frame replacement.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Had and still have the same problem, certain cause for this is that screen replacement is glued to the midframe, unlike the original one which is double-taped.. as you said, heat does play a strong factor considering it heats and evaporates the glue causing these touch sensitivity problems.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
ChemE TechE sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 120
