Ana içeriğe geç
2015 Mart ayında duyurulan ve 10 Nisan 2015’te piyasaya sürülen Galaxy S6, Galaxy serisinin önde gelen ürünüdür. Kavisli ekran versiyonu Galaxy S6 Edge olarak bilinir.
I cannot get the charger into the slot
I cannot get the home charger into the slot - it will not go in
Bu iyi bir soru mu?
Puan 2
1 Yorum
I bought 2 new 10 inch Lenovo tablets from best buy, and one of he tables pots was very difficult to plug, and now I can see that it looks like the pins are damaged. Do I have any recourse for these. I have had the tablets 10 days.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check for damage to the port and to the charger look for bent parts or dirt in the port or lint in the port
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
the port looks like bent parts, what do I do? I had not taken out the service agreement with Walmart; they said the port needs replaced and to take it to a pc repairman. It is only 6 mos. old and I thought I should have gotten better service than that. Don't they have a year's warranty?
tarafından
A bent port wont be covered by warrenty its considered damaged by owner The charge port is fixable yourself its time consuming but if you take your time very doable
Samsung Galaxy S6 Daughterboard Replacement
this is a how to guild
http://www.amazon.com/Sunways-Charger-Co...
tarafından
http://www.eddogo.com/charger-charging-d...
Here's a SM-G920F version of the charger port. Make sure you have the correct model number of the charging port or else you will run into charging and mobile network / service provider signal issues.
tarafından
Yorum Ekle
excellent tweezers saved the day. grass seedsfrom weeding and whiskers from my sink looked like dead bugs.
sewing needle worked at first, but the tweezers really pulled out the big stuff.get a better case with a cover for that spot.
Puan 0
Yorum Ekle
Yanıtını ekle
trudy6261 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 21,344
